Volhv's Avatar
Left wheels stick out more than right wheels
Just noticed that my rear left wheel is out more than the right one.... Also noticed the same thing with the front wheels, but it's not as noticeable.
Any idea what could be wrong?
Looked underneath, and it does not look like any of the mounting points are bent. While I do need to get an alignment, I don't think it being off, would cause it to be that much off....
Also, I have 15" Fuchs, and did double check that the aft ones as indeed both 8s, and front are 7s.
1986 944 NA Sapphire Metallic
http://944porsche.blogspot.ca/
Old 07-30-2013, 11:11 AM
Toofah King Bad
Rasta Monsta's Avatar
Nothing wrong. . .a guy over at the 924 board noted this a few years ago. . .
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-30-2013, 11:25 AM
Volhv's Avatar
Really?
That's a relief.
Does it have something to do with better centering the driver's weight between the wheels.... to improve handling.
I also noticed that the right axle was a tighter fit when installing.
Old 07-30-2013, 11:40 AM
FrenchToast's Avatar
I believe the body is shifted slightly on the drivetrain to compensate for driver positioning. But I think only a few mm's max. And I don't think it should affect the axle fit.
I don't think it should be 'noticeable.' It gets noticeable when you're pushing the limits of tire sizes.
Take care,
Old 07-31-2013, 06:17 PM
Volhv's Avatar
There is an oval hole, where the torsion bar support mounts. Would that affect the positioning of the hub?
Thank you for the input.
Old 07-31-2013, 09:30 PM
curtisr
curtisr's Avatar
At the risk of stating the obvious: a small spacer on the offending side should balance it out.
Old 08-01-2013, 08:18 AM
Frankly my dear....
rhett's Avatar
If that is the case, that would be good for all you LHD owners...but not so good for us RHD owners.
I have a feeling that the tolerances on these cars are not too good and there are several areas where they are a bit asymmetrical - the shell was designed back in the 70's - they didn't have much CAD gear around then!
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 08-01-2013, 12:04 PM
Volhv's Avatar
Maybe the RHD cars are shifted the other way.
Old 08-01-2013, 01:53 PM
