Send a message via Yahoo to bigyagi
door side mouldings
84 944. the passenger side door moulding is starting to come loose. its still attached at either end, but its coming away in the middle.
how is this attached ? is it just some kind of waterproof epoxy or what.
when i pull it away from the door, in the middle, i can see a rubber strip all along its lengh, but no obvious sign of clips or anything.
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 08-04-2013, 06:38 AM
alan6272's Avatar
its 2 sided tape 3m makes a good product you can use but you will have to remove the strip and clean old tape off.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 08-04-2013, 02:18 PM
Proprietoristicly Refined
John_AZ's Avatar
A careful, thin, 2mm bead of Black Silicone Adhesive
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 08-04-2013, 03:07 PM
DinoDanny's Avatar
Ditto. The 3M body trim tape is the way to go. That or something very similar is what was used originally. Most auto supply stores carry it. You can use dental floss to remove the moulding. Just make sure you have all of the old tape off both the moulding and the body and everything really clean before re-installation.
Danny
1987 Porsche 951
2003 Kawaski ZX-12R
2008 Kawasaki Concours 1400
Old 08-05-2013, 10:29 AM
could you post a part number so people like me know what this is?
Old 08-06-2013, 07:14 AM
