-   -   Cam tower install experiment (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/764637-cam-tower-install-experiment.html)
Rob Chamberlain 08-06-2013 02:39 PM
Just wondering given the number of different tricks to cleanly install the cam tower without the followers falling out...grease, sheet metal, prayers to the Porsche Gods etc. Is it possible for a strong magnet applied to the cam gear to magnetize the cam enough to temporarily hold the lifters enough to play 'bombardier over Moscow' to position the tower on the head without so much drama? Of course would be nice in removing the tower as well I guess. Just curious if anyone has tried before...else I will try it and report back on failure or success.
krystar 08-06-2013 03:43 PM
lol bombadier.
grease works. even heavy oil works.
what u do is hold the cam tower upside down, position it on pass side of the head. slowly rotate until followers are horizontal, by which time u should have cleared the strut tower. the quickly rotate and drop onto the valves. some followers might fall halfway but u can wiggle em back in.
Volhv 08-06-2013 04:15 PM
I found that dental floss works well. I've done it this way twice.
http://4.bp.blogspot.com/-m_eOrxx778...1600/floss.jpg
mytrplseven 08-06-2013 04:15 PM
I just put a piece of stiff cardboad on top of the lifters with the tower upside down. put a few loops of dental floss around it to hold it in place. turn it over and lay it on top of the engine. Cut the dental floss and pull the cardboard out. Shazam!
Slam 08-06-2013 05:43 PM
Old-fashioned wooden yardstick. Assistant.
Or a little grease.
Rob Chamberlain 08-06-2013 06:23 PM
Wow...thanks for all the help/ suggestions! I was successful before with grease, but felt more lucky than confident which is why I was looking for a better method. Thanks!!
GreenWater 08-06-2013 07:23 PM
Grease and a big hammer works perfectly. If they fall out just hammer them back in really hard. Just kidding, don't really do that.
I've done it twice and I just used grease and did like Krystar said and they went right on. Maybe a little luck too.
POPS 83 944 08-06-2013 10:51 PM
[QUOTE=GreenWater;7588636]Grease and a big hammer works perfectly. If they fall out just hammer them back in really hard. Just kidding, don't really do that. /QUOTE]
Here is a photo of GreenWater and his helper getting ready to work on his 944
http://i1158.photobucket.com/albums/...ege/th-3-1.jpg
:D
PorscheChef 08-07-2013 08:25 AM
I have always just use some wheel bearing grease. Never had an issue with them slipping out.
mikepellegrini 08-07-2013 11:40 AM
+1 on grease. Assembly grease works great.
nynor 08-07-2013 06:57 PM
+1 on grease. done it that way three times.
GreenWater 08-07-2013 08:23 PM
POPS, I use a much bigger hammer than that! ha ha, that was funny.
