1990 944S2
Two easy questions (timing belt, cam, pump)
Hi all
Doing an inner cam cover and a water pump switch while renewing belts, pulleys etc. on a 1984 944/1, everything stock. Two questions: 1) The cam timing gear is held to the camshaft by a bolt. Does this bolt have a reverse thread? (i.e. righty tighty, or lefty tighty?) 2) Somewhere during reassembly of the water pump, timing and balance belt systems, I've heard mention of a part that might need Loctite. Which part might that be? Thanks! Cheers Chris |
Cam bolt is "righty tighty".... but you only need to remove it, if you are changing the seal behind there. Honestly, since it spins at 1/2 the speed of the crank, it should have worn less than say, the balance shaft seals, those guys spin at twice the crank's speed, so effectively they have 4x the cycles the cam seal would have.
1986 944 NA Sapphire Metallic http://944porsche.blogspot.ca/ |
Proprietoristicly Refined
1. Standard --bolt.
Bennington Motorsports 2. WP bolts should use Loctite 270 . Torque 8Nm BUT-- Read the note at the bottom of the page in Clarks-Garage Water Pump Information and Replacement GL J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
1990 944S2
Thank you gents!
CRL |
Back from Beyond
You know, I've always kinda thought using any sort of thread-locker on those baby bolts would result in pain and suffering. They're already prone to seizing as it is. I use copper antiseize and have never broken one and never had a leak in over 15 years of doing that job.
Am I looney or lucky? Oh, almost forgot: always use a new cam sprocket bolt (speaking of bolts that like to seize...). Last edited by Slam; 07-25-2013 at 07:12 PM.. |
In the Fires of Hell.....
Balance shafts spin at TWICE the speed of the crankshaft, not half...
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
1990 944S2
Done deal.
Many thanks to all! Cheers Chris |
