-   -   Ready to crank for the first time what am i forgetting (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/765116-ready-crank-first-time-what-am-i-forgetting.html)
mhr 08-09-2013 08:54 AM
So because of no oil pressure when I started her up in the spring, for the last 4 months I have been working my 91 S2.
It was a case of every layer of the onion I peeled away I exposed something that needed to be fixed.
As of last night it is all back together except some suspension stuff. Honestly I am nervous to crank it up. Here is the list of what I have done:
Rod bearings
Oil pan gasket / Pickup and return seals
Oil cooler/filter console removed cleaned new seals (installed with alignment tool)
New used nice condition OPRV
New used nice condition Oil pump
New oil pressure sender
New oil pump drive
New water pump, thermostat
New belts (all rollers and idlers are only 2 yrs old so did not change them)
New main and balance shaft seals and o rings
Every other seal and gasket that I came across
New rear fuel lines
New tie rod ends
New motor mounts
New fitting for power steering reservoir to pump hose
New plugs, wires
Although I have done some work on the car over the last 4 years this is the deepest I have ever gone and cranking it is making me nervous.
Anything anyone wants to suggest I double check before connecting the battery and cranking away.
944 Ecology 08-09-2013 09:07 AM
Before connecting the battery, remove the spark plugs and hand crank the engine to make sure that there are no binds anywhere in the rotation.
After that, connect the battery and use the starter to crank the engine and check if you have oil pressure indicated on the gauge.
Then, install the plugs, cross your fingers and try to start the engine.
Let it run for about 15 seconds, then stop and look for leaks.
Fix whatever leaks you find, then run it for about 5 minutes.
After that, it should be good to go.
John_AZ 08-09-2013 11:30 AM
What George Said,
Fully charged battery.
Prime the oil pump.
Try these tips or search for more.
PorscheDoc is a pro mechanic:
priming oil pump - Rennlist Discussion Forums
Remove the DME/Fuel pump relay when you check for oil pressure. Prevents fuel from washing cylinder walls and ending up in crankcase.
RECHECK all top of engine electrical connections--like the AFM main cable. Put back DME/FUEL pump relay.
GOOD LUCK!
J_AZ
mueller944s2 08-09-2013 12:05 PM
you can have the plugs in just pull the plug at the distributor and there won't be any spark.
mytrplseven 08-09-2013 12:20 PM
Pulling the plugs will allow you to hand crank the motor a turn or two to ensure there's not mis-timing of the timing belt or anything else mechanical before turning to the electric starter. All of the above notes are a good step-by-step guide to make sure all your hard work will have positive results. Good luck in your testing.
John_AZ 08-09-2013 12:43 PM
Competition Engine Break In Procedures:
"Competition Engineering - Break In Procedure for Engines assembled by Competition Engineering"
Did you notice the warning on Synthetic oils and cam shafts??
J_AZ
mueller944s2 08-09-2013 01:07 PM
J_AZ
What car is that procedure for? I just noticed it said 3 quarts and was confused..
Bukowski 08-09-2013 02:26 PM
I suppose this goes for any car that has sat for many months, the oil pooling down somewhere away from where it is supposed to be?
that is, would it be recommended for any sort of long-term repairs, or extra cautious if the engine went untouched... or something else...
jeffrsmith 08-09-2013 02:49 PM
Also, don't forget to cross your fingers.
No matter what you do, or how well you prepare, there will always be a very large amount of apprehension the first time you turn the key after performing major work.
There are a lot of very good suggestions presented by those who I am sure have much more experience than I and they all sound like very sound recommendations.
I still consider myself a novice, I have torn down and rebuilt seven engines, only one of which was a Porsche (my current 944). Every time I turn the key for the first time I am very nervous that I have overlooked something.
Good luck
John_AZ 08-09-2013 03:49 PM
Nice catch.
Probably an engine with a smaller crankcase.
5 quarts (min dipstick mark) in the 944 and one quart used to prime the oil pump depending on method.
J_AZ
mytrplseven 08-09-2013 06:55 PM
I was a commercial pilot and I always crossed my fingers when starting the engines :)
mhr 08-10-2013 04:39 AM
SHE'S ALIVE:)
Put oil in both holes in the oil filter console and hand cranked it for a couple of minutes. They cranked with the starter for about 15 seconds and saw oil pressure. So fired her up.
Oil pressure is strong and there are no leaks that I noticed yesterday. I will take a look this morning o see if any developed over night.
Holds an idle well but if I rev it when the rpm's drop back down it stalls. I am going to look around today for any vacuum lines that may be unplugged etc and report back.
Thanks for the advice and encouragement.
John_AZ 08-10-2013 05:02 AM
Nice!!!
Great to hear.
Check the wiring to the AFM and look inside to make sure the "door" is swinging freely.
Under the intake "J" tube----an easy place to have a loose connection or broken plastic part.
J_AZ
mhr 08-10-2013 05:06 AM
Will check the AFM and clean the connector. I already know that I am missing the metal clip that holds the plug into the AFM. Anyone know if I can purchase it somewhere?
John_AZ 08-10-2013 05:18 AM
The "U" shape metal clip sells for about $4 to $??? + s/h new.
I would send you a spare if I had one.
Maybe someone who replied or post another thread WTB and a generous member will have it.
J_AZ
mhr 08-10-2013 07:27 PM
thanks John I will ask around for the clip.
So I still cant get it to idle well. It seems to run ok perhaps not as smooth as it should but good oil pressure and stays cool. I ran it for quite a while in the garage and the temp never got hot enough to kick the fans in. But as soon as I give it gas as I come off the gas it will drop down and stall.
I got the rest of it together and took it for a very short drive around the block and it stalled at the stop sign as soon as I put in the clutch from second.
So far I have looked around and did not see any vacuum hoses disconnected. Checked all hose connections and they look good. Cleaned the AFM and ICV connectors and replugged them.
Next I guess I will take the hose off the AFM and make sure the door is not stuck. What else should I be looking at.
Could it possibly be that the gas in the tank is too old. I filled it up in late October when I put it away. I did add stabil but I wonder if that could be a problem.
Or any chance I could have messed up the timing somehow which is making it run kind of rough and not hold idle.
Any opinions or advice is appreciated.
thanks
Mark
mytrplseven 08-11-2013 06:31 AM
The list is long of things that could cause your problem. There's some easy and cheap steps you can do to check your vacuum system. Get a 2" PVC cap from Home Depot and drill and insert an air hose fitting in the middle. Insert the cap into the intake of the J boot and clamp it down the the ring clamp. Apply no more than 10psi to the fitting and then go over the entire engine with soapy water solution from a spray bottle. Even under the j boot and the intake manifold. Look for bubbles. I even had bubbles from my throttle body (small rubber seals in the shaft). Once you've solved all the leaks, look for spark plug wires out of firing order, loose connectors on the fuel injectors, loosed connections on the DME temp sensor, TPS and AFM and spark plugs and distributor. Also make sure you didn't crack an insulator on a spark plug when installing it (it happens). I'll connect a couple of pics for your consideration.
http://forums.pelicanparts.com/uploa...1376227831.jpg
http://forums.pelicanparts.com/uploa...1376227862.jpg
mhr 08-11-2013 06:54 AM
I think I am running on 2 cylinders. I just ran it and it just sounds weird kinda like a Harley. I took the temperature if the headers and cylinders 1 and 4 at at like 350f but 2 and 3 are like 150.
I checked the plug wires and they are correct but could I have made a mistake when I put together the distributor/rotor?
mhr 08-11-2013 07:57 AM
Never mind. Always the stupid things left for last. I reversed plug wired 2 and 3. She is running FANTASTIC. Going for a drive. :):)
John_AZ 08-11-2013 09:53 AM
http://forums.pelicanparts.com/suppo...ys/men_ani.gif
http://forums.pelicanparts.com/support/smileys/wat3.gif
http://forums.pelicanparts.com/suppo.../FFflower2.gif
http://forums.pelicanparts.com/suppo...sun_smiley.gif
Well done!
J_AZ
mytrplseven 08-11-2013 03:09 PM
Yeeehaaaa! Like you said, "it's always the simple things".
mhr 08-11-2013 06:45 PM
Spent the afternoon looking for excuses to drive places:) Was a nice warm roof down kinda day.
Oil pressure looked good. About 4.5 bars at idle when cold and after it was totally warmed up just slightly below 2 bars. When touching the gas at all up to 4 or 5 bars.
One of the times I started it, it took about 5 seconds to get oil pressure which is a bit worrisome so obviously I will continue to watch it carefully. Temp was perfect,
Only see one leak from the top rear of the engine which I have always had and did not address this time. Otherwise the plastic I have under the car is clean.
Going to try to get an appointment for an alignment early this week so that I can do some highway driving next weekend.
Thanks for all the help and advice.
Mark
mytrplseven 08-12-2013 08:40 AM
Sounds like that cork gasket on the rear end of the cam tower. Easy to fix...don't overtighten it.
