battery dying every day
Hey guys i have an 87 944 N/A and the battery keeps dying every day. I jump it and it works fine. I keep all the lights off always but i notice the clock is always on. Is there any other things that are always on and can you shut off the clock
Old 08-13-2013, 08:56 PM
AFM #725
Gawernator's Avatar
It's not the clock.. do you have an aftermarket sound system?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 08-13-2013, 09:05 PM
winter-hater club member
nynor's Avatar
weak battery?
"COOL PRIUS!" - Nobody Ever
Old 08-13-2013, 09:26 PM
yeah.... Im guessing that might be it. theres also a set of interior lights that were put in but removed, the cables and switch is still there.
Old 08-13-2013, 10:04 PM
AFM #725
Gawernator's Avatar
Check the battery first
Old 08-13-2013, 11:18 PM
Patrick
pfarah's Avatar
Most car parts stores can perform a battery load test, just ask. Also, look at the battery water levels and only use distilled water if they're low.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 08-14-2013, 03:21 AM
You don't want to jump a 944. The DME Computer is very sensitive to that and you may be rebuilding it if you continue to jump the car.
Old 08-14-2013, 04:15 AM
Just thinking out loud
mattdavis11's Avatar
Quit hitting the turn signal when you get out of the car.
91 FJ80
84 Ram Charger (now gone)
Old 08-14-2013, 07:30 AM
James Chimney
Check the charge of the battery after a drive, then disconnect the battery (both sides + & -) the check it in the morning if it held the charge the battery is ok if not just pop it out and get another (take it with you), if it held the charge you have a draw.
Old 08-14-2013, 10:37 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
The alarm system could be the culprit, too, assuming you have one. It caused the same issue in my wife's car. But, again, check the battery condition first.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 08-14-2013, 11:45 AM
im going to check the batt first then go from there,
Old 08-14-2013, 01:13 PM
Fernie_Wan_Kenobi
fmartinez1897's Avatar
so your battery isn't holding charge. I say have your alternator checked.
Old 08-14-2013, 04:03 PM
i dont think that its not holding a charge i think something is draining it
Old 08-14-2013, 05:05 PM
This link should help...
http://www.clarks-garage.com/pdf-manual/elect-26.pdf
Old 08-14-2013, 05:14 PM
Originally Posted by djnolan View Post
couldnt get to the website, gave me a 404 error
Old 08-14-2013, 06:54 PM
gtroth's Avatar
What's your current draw when parked?
You measure this with an ammeter in series with the battery (don't try to start the car when connected this way or you will blow the fuse of the meter).
If it's higher than ~ 60mA, start pulling fuses one at a time until you see the current drop. That will be your leaky circuit which will help you track it down.
Are your radiator fans staying on by any chance?
1995 993C4 guards red
1988 944S alpine white
Old 08-14-2013, 07:10 PM
AFM #725
Gawernator's Avatar
Use this link: Excessive Battery Discharge Rate
Old 08-14-2013, 07:11 PM
gtroth's Avatar
Nah. Just leave the other car off while jumping.
Old 08-14-2013, 07:12 PM
I dont have an ammeter... time to go to the neighbors!
Old 08-14-2013, 07:22 PM
AFM #725
Gawernator's Avatar
Time to get one, you have a 944
Old 08-14-2013, 07:24 PM
