Squealies
1987 Porsche 944S.
Okay so i got a hold of some manifold gauges and some r-12. so i figured what the hell i might as well check on the system. pressures were a little low so i hooked up the r-12 to the low side and starting re-charging.
after about a minute the air intake filter fell off and the engine shut off(just got this car about a week ago and im still correcting problems). i shut down the recharge and put everything off to the side while i put the intake back on and started the car. immediately i heard the squealing of belts so i shut the car off. i took a look under the hood and there was smoke coming up from the A/C compressor pulley. also the belt was pretty warm to touch.
i turned off the AC and started the car back up, everything was fine. turned on the AC and the squealing happened again. turned it off everything was fine. basically my question is, does this sound like a seized compressor and can i drive the car with it in this condition or should i change the belt and compressor before driving it.
Old 08-22-2013, 03:56 PM
AFM #725
Gawernator's Avatar
Air intake filter.. fell off?!?!?!
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 08-22-2013, 04:35 PM
tamathumper's Avatar
Hate to ask, but is it smoke, or is it refrigerant from a (now) overcharged AC system?
Old 08-22-2013, 04:41 PM
yea i kno the hose clamp was not actually on....so the whole assembly fell off. and its definitely smoke from either the belt or the clutch. smells like burning rubber
Old 08-22-2013, 08:45 PM
AFM #725
Gawernator's Avatar
There should be a bracket and bolts holding the whole airbox/assembly to the car.. not by a hose!
Old 08-23-2013, 12:29 AM
jhowell371's Avatar
Sounds like a cone filter fell off. My guess is the compressor locked trying to compress liquid R12 from overfill.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 08-23-2013, 05:05 AM
Yes it was a cone filter. And according to my gauge manifold the pressure is still at zero. pretty sure its empty. anyway im more worried about the belt than the compressor cause the belt got a little warm. i was planning on driving the car from new york to virginia on sunday. but im thinkin mayb i should hold off on road trips until i change that belt. any thoughts
Old 08-23-2013, 09:49 AM
Chunkerz's Avatar
Sounds like the compressor is locked up. I'd change that first.
Old 08-23-2013, 10:25 AM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
sounds like the gauge that tells you the pressure wasn't fully engaged and it read zero while you were actually overfilling the system. To be safe, take it to an AC place to get it right. The burning smell and smoke is fromt the belt trying to drive a seized up compressor.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
