-   -   Windows problem.. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/766707-windows-problem.html)
Gordon Rankin 08-18-2013 06:40 PM
Windows problem..
OK... Here is another question.. I drove my car down to the beach today for a meeting.. Car ran well.. I have had problems with the windows in the past. One window would stop then the other would not work.. Anyway, today one of the windows stopped working.. I have replaced the relay, twice. I have checked the fuse.. I have changed the switches ( 1983 944 N/A) I cant figure this out.. Any ideas??
alan6272 08-18-2013 06:49 PM
check for power at the window motor, maybe the motor has a bad spot for the brushes.
pfarah 08-19-2013 06:25 PM
Alan has a very good suggestion. I had the same issue last year and after messing around with everything else, I removed the regulator motor and thoroughly cleaned the brush contacts (and all other internal components). The shaft bearing/bushings were re-lubed and it came back to life!. It may be something to look into...
