i will replace the back suspension system with and i want to know what is the maximum O.D of the coil that it could fit .and if anyone knows more it will be more helpful.i all ready search the older posts but i didn't found something useful.
my car is 944 S2 |
nobody knows?
Try looking at 944online forum. They have section for track cars, maybe you can get an answer there.
Red 84 w/25,xxx miles Stone Gray 89 S2 w/90,xxx miles |
2.5in is a regular size spring for coilovers made for our cars, 2.25in is also available for some coilovers.
I'm not quite understanding your question though. Generally coilover springs are 2.5in as you can get almost any spring rate you want in that size, but it depends on the strut you are using. |
That Guy
2.25" is a must, 2.5" will only work if you space the lower shock mount out from the trailing arm.. but this is not ideal because you are putting more stress on a already weak spot in the suspension; the lower shock mount.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
AFM #725
Yeah, 9FF and I have the rear shocks run inverted to deal with that clearance issue..
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
