jlking2's Avatar
Wheels for '88 944 S2
Recently purchased an '88 944 S2 and was hoping someone can advise is if a set of 17 inch wheels with 9x17 ET 47 with 255/40ZR17 (rear) and 7.5x17 ET 52 with 205/50ZR17 (fronts) will fit this car?
Thanks Jerry
Old 08-22-2013, 05:22 PM
racer's Avatar
Yup.. they'll fit (assuming 5x130 bolt pattern)
btw, S2's weren't offered till '89, not '88.
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 08-22-2013, 05:36 PM
jhowell371's Avatar
Post a pic of them for identification. I'm looking to replace the 7 & 8 Cup Ones I have on my S2 with 7.5 and 9 inch when I see something I like.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 08-22-2013, 05:38 PM
tamathumper's Avatar
They may fit, but there's a Porsche advisory about fitting 17's to the 944's. Probably available by Google search. The nutshell version is that the suspension bits aren't up to the task.
Old 08-22-2013, 05:43 PM
jlking2's Avatar
Thanks I'll post a pic if I acquire.
Old 08-22-2013, 05:54 PM
racer's Avatar
Technically, yes, it wasn't till the 968 that Porsche authorized use of 17's on the "944 series" cars. I believe they changed a bracket or bushings in the front suspension to cope with the additional cornering forces of the larger wheels.
That said, they fit.
Past:
Old 08-22-2013, 05:59 PM
jlking2's Avatar
Racer yes you are correct the "S2" wasn't until '89...wishfull thinking on my part.
The car is currently set up for DE/street with the "ugly" 15" phone dials for the street and a set of 16" BBS 3 piece wheels for the track. Thought i'd like to up grade the street wheels as I found a set of 17 " twist 5-spoke that i think would look great for the street thus, my question about the 17" and offset. With the upgraded suspension I have on the car I think it would handle any street use i do with the car.
Again, appreciate everyone's quick response...the Pelican network is a great source for info and not to mention they sell some reasonably priced goodies for the Porsches!!
JK
Old 08-22-2013, 06:16 PM
racer's Avatar
205/255 stagger is pretty large. Fine on the street. Annoying on track/de/ax. You'd want at least a 225 front.
Boxster/996 wheels are a simple find a bolt up just fine. Lots more tire choices in 17"s than 16"s.
I'm suprised the 15"s will clear the front brake calipers.
Past:
Old 08-22-2013, 07:14 PM
gtroth's Avatar
I *think* all you need to do is upgrade to 968 caster blocks to run 17s.
Great upgrade for any size, really.
So is this an 88 or 89 (S or S2)?
1995 993C4 guards red
1988 944S alpine white
Old 08-23-2013, 12:59 PM
gtroth's Avatar
Excellent. So castor blocks and eccentrics. Good to know.
Old 08-23-2013, 07:01 PM
