Lighter, always lighter.
I started to really clean the inside of my Cup car. the sound deadening was out but there was a ton of glue under the carpets, and these are badly torn at places (from some different cage the idiot PO put in)
So in front it looks about stock:
but in the rear...
The last few months it got a lexan rear hatch, some grooved slicks, a small washer bottle, and now I tried it as is.
Wow, it really flies now, And the slicks throw up lots more stones in the wheelwells, you'd swear you're in a cabrio, or a window is open.
I'll eventually put the carpets back in , but I thought I'd show you this
GeorgeK
Old 08-04-2002, 07:49 AM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
Thumbs up
Looks SICK!!!!!!!!!!! Two thumbs up....what did the cage run you? -chris
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 08-04-2002, 08:12 AM
overkill's Avatar
Send a message via AIM to overkill
Thats a bolt-in cage right? Looks it. God, I can't wait to get my car.
{1987}944S - (SOLD).
Old 08-04-2002, 08:14 AM
overkill's Avatar
Where can I see pictures of a 944 without the dash on?
Old 08-04-2002, 08:16 AM
Chris, Overkill The cage is the original, the car was the celebrity guest car in the French turbo Cup, run '88-'90. It is a matter alloy cage. The PO took it out, then had a Heigo unit put in, painted red, and fastened at all the wrong places... I re-put the original cage in. Does wonders for the car.
GeorgeK
Old 08-04-2002, 08:36 AM
I'm doing this to my car right now.
How did you clean out all the glue and fuzz? How did you paint it?
Old 08-08-2002, 12:12 PM
Hi Eligunn
I used two products:
the first is Prepsol, a solution used by my body shop friends to clean and degrease,
the other is rectified benzin.
AND a scraper...
Don't do that in a closed room, unless you fancy the headache of a lifetime.
The interior color is as it was. The car has had at least three colors in its life.
Regards, GeorgeK
Old 08-08-2002, 09:35 PM
