fix fuel filter to distributor furl line
My gas line is leaking right where it connects to the filter can this be fixed? Its the one coming from the filter to the fuel distributor on a 79' Porsche 924.
Old 09-06-2013, 12:36 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
You can replace the line if the fittings aren't tight. I'd replace the filter at the same time, especially since their cheap.
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 09-06-2013, 12:44 PM
The filter is brand new and so is the pump. I'm guessing that the new fuel lines were no match for a new pump.
Old 09-06-2013, 03:46 PM
In the Fires of Hell.....
kdjones2000's Avatar
CIS runs higher pressures than does Motronic, so your lines need to be in pretty good shape.
If you can't find a source for the line I would try "Auto Haus AZ", as I have been able to get CIS lines from the dizzy to the injectors from them at a good price.
Good luck!
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 09-07-2013, 06:48 AM
