-   -   Speed/Reference Sensor Testing Help (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/770168-speed-reference-sensor-testing-help.html)
9fourteen 09-09-2013 04:44 PM
Got them out. They slid right out. Barely had to work them at all. Just used my hands. They were probably out when they did the clutch about 8 months ago so they hadn't seized up yet.
http://forums.pelicanparts.com/uploa...1378769612.jpg
I noticed on the one being used as the speed sensor it had a dent on the top edge on one side. Clearance problem? Kind of hard to see in the image but here is a picture of it. Do you think I should check the bracket clearance?
http://forums.pelicanparts.com/uploa...1378769692.jpg
http://forums.pelicanparts.com/uploa...1378770184.jpg
The reference sensor continues to test up correctly. I was able to test it directly connected to the sensor. The reason why it wasn't working for me before was I was looking at the pins in reverse. I don' t know if my bracket is upside down but my connectors are the opposite of what is shown on Clark's page. I figured it out when I looked at the keyed part of the connector. The speed sensor continues to be dead.
http://forums.pelicanparts.com/uploa...1378769897.jpg
Rogue_Ant 09-09-2013 05:38 PM
Originally Posted by 9fourteen (Post 7647415)
Which sensor will cause the tach to bounce? Or is it a combination of them both?
Both need to be working properly. (well, technically, the speed sensor could be partially working and the tach might still bounce - assuming a good reference sensor)
pfarah 09-09-2013 05:47 PM
My old sensors tested within range but I think the magnets were just tired. The car came right back to life upon replacement.
9fourteen 09-14-2013 03:50 PM
Replaced both sensors and it fired right up.
GreenWater 09-14-2013 03:53 PM
Awesome. Glad to hear your car is fixed.
9fourteen 09-14-2013 04:00 PM
Running, not sure if I would say fixed yet. This car is far from perfect and needs sorted out. I'm starting a list of things that need done. I just started a new thread for the next issue, engine is making a clicking sound.
