smokin_944's Avatar
door pulls Series 1 and later cars
Does anyone know if the door pulls are the same on the early and the late cars? I have an early car and bought black door pulls to swap out the brown ones and found out that they aren't the same. The angle of the bolt above the handle is different and the door pull doesn't sit correctly. Any ideas?
1984 - 944 Black / Wilwood/Brembo brakes / fresh M-474 suspension / Welt 250 lb fronts / 28 mm solid T-bars / M030 bars w Racer's Edge hardware/MSDS headers
Old 10-07-2013, 12:10 PM
smokin_944's Avatar
Surely I'm not the only one who's encountered this problem?
Old 10-08-2013, 12:46 PM
Frankly my dear....
rhett's Avatar
Well, perhaps to an extent you have answered your own question as you have already found out that they are not the same...
The design was changed when the 85.5 series cars (oval dash) was released. The door cards are different, as are the door pulls. I am not sure if they are compatible in any way as even the shape of the pull surround is different.
However, I would have expected that you could probably find a set of good black early pulls to replace your brown ones?
Porsche - accept no substitute
Blue 1999 Boxster - Brief encounter! Black 1988 944S - Ongoing project
Black 1987 944S - Gone but not forgotten
Metallic Black 1980 924 - Those were the days....
Red 1979 924 - Hmm Minerva blue 1979 924 - Where it all began!
Old 10-08-2013, 01:10 PM
