Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
rschnvr's Avatar
924S fuel odor source unknown
When I start the engine on my 1987 924S and lower the windows I can smell a gasoline odor. There is no obvious fuel leak in the engine compartment or beneath the car. The odor seems to go away when I drive with the windows up as well as when the fuel level in the gas tank goes down below about half full. And I believe gas mileage is less than normal.
Any ideas on where to look for the source of this?
Previously owned: 1977 924, 1978 911SC Targa, 1986 Carrera Targa
Currently: 1985 Carrera Targa, 1987 924S
Old 09-16-2013, 03:55 PM
Proprietoristicly Refined
John_AZ's Avatar
Usually around the fill hoses on the inside of the car.
Remove the carpet and metal panel and check for cracked hoses.
Remember to seal the metal panel again with a black rubber sealant.
OR (very common----every 924S tank I have seen. Both tanks on my cars and the spare tank on the shelf)
One of many posts.
Gas fumes? Tank leaks? Read this.
GL
J_AZ
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 09-16-2013, 04:19 PM
rschnvr's Avatar
Thsnks, and thanks for the link to a great thread.
Old 09-16-2013, 08:24 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Check vent hose at gas filler.
Later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968 & 911 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 09-16-2013, 08:52 PM
I don't know if 924's are like my 87 944 NA, but you said something like "no obvious leak below the car".
what does it actually look like near the fuel filter? specifically, the fuel-pump-to-fuel-filter hose, or the fuel-filter-to-fuel-line hose?
mine were horrific. it was not "obvious" until I got under there, and hoo-boy, talk about time to replace them.
87 944 NA
Old 09-17-2013, 06:24 AM
rschnvr's Avatar
Thanks, guru944 and Bukowski. Having read the thread that John_AZ posted a link to, I'm thinking the fumes are more likely associated with the carbon canister and lines in and out of that. I'll be working on the car later today, and will check the other areas, which I have a feeling probably need to be fixed, too. I do know from the PPI when the car was up on a lift that the fuel lines around the fuel fuel pump aren't great
Based on everything I've read, too, I'm sort of expecting there's a minor crack and seep/leak in the fuel tank, too.
Old 09-19-2013, 09:05 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
