Removal of the wiring for the Fader Rheostat
Before I break something does anyone have any thoughts on how to remove the wire harness on the bottom of the fader rheostat switch so that I can completely remove it from the console. I no longer use it but would like to take it apart to clean and detail then reinstall. Thanks Ralph
RPorzio 84 944 |
If I remember correctly, the harness is pretty short - it only runs up behind the radio. There are two plugs at that end - one went into the original radio, the other went out to the speaker wiring in the car (the rheostat was in between the two)
I would bet if you pulled the radio out, you'd be able to find the other ends and feed it back through the console. Once it's out, I'm sure you'll see a way to disconnect the harness from the back of the fader rheostat itself.
-John '94 968 Iris Blue '85.5 944 White - Rally Cross and wrenching practice '84 944 Gemini Grey (gone, but missed...) |
ok, that's good because the original Monterey has been out of the car for years and I'm now in the process of changing out my current head unit so that will be a good opportunity to try your advice; thank you! Ralph
RPorzio 84 944 |
Misunderstood User
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway Last edited by jcommin; 09-17-2013 at 02:54 PM.. |
