mhariush's Avatar
Letter from Porsche regarding 944 S Power Steering Switch failure
in case someone found this interesting.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 2006 Cayenne, 80 924 Turbo, 69 Beetle
instagram @mhariush @technikercompany
http://stores.ebay.com/Techniker-Parts/
Old 09-20-2013, 10:39 PM
Actually, the unfused switch caused wiring harnesses to melt... Even today, it's an expensive repair.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 09-21-2013, 09:36 AM
Aussie944S's Avatar
Got told to unplug the wires and tape the connectors then zip them up.
How would one tell if this modification listed in the letter been done, I see nothing of the sort in the service history with my car or on the recall stamp card.
Old 09-23-2013, 02:36 AM
Look at the switch on the PS pump. If it is electrically connected, the work has not been done. You can do the work yourself.
www.944ecology.com
Old 09-23-2013, 03:38 AM
mhariush's Avatar
I think the fix they did is the black and yellow wire that runs from the ps pump to the connector in front of the fuse box (in the engine bay). That wire has been added into the connector and through the grommet in the firewall and then into the fuse box after the car left the factory.
But I could be wrong.
The best fix is just to disconnect them and tape up the connectors. On my last belt/seal/manifold work I removed the wires from the car altogether.
Old 09-23-2013, 09:35 AM
Aussie944S's Avatar
Cool well there unplugged and taped as I was told to do this from another website... for the life of me I can't remember the website.
Anyway cheers guys
Old 09-24-2013, 03:44 AM
tamathumper's Avatar
From the letter, it sounds like the fix was to add a fuse to the circuit, not to disconnect the wiring entirely?
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 09-24-2013, 04:08 AM
Is that the offending wire? I've never known what that was lol and at times its not connected.
Old 09-24-2013, 09:38 AM
Yep, that's the one.
The PCNA fix of adding a fuse was to keep the (totally unnecessary) anti-stall switch functional without causing a fire.
www.944ecology.com
Old 09-24-2013, 09:46 AM
That wire always did look a little fishy. So now if thats the wire thats causing the problem, how should I sort this out?
Disconnect it and tape the end?
Rig up the fuse and such per the letter from porsche?
Take it to Porsche and have them do it on da house?
Old 09-24-2013, 11:42 AM
mhariush's Avatar
Just disconnect it and tape up the connectors so they don't accidentally cross. You don't need this function.
I removed the wire completely from the harness. Didn't like having a useless wire running around in there.
Old 09-24-2013, 12:16 PM
