| 944noob |
09-22-2013 10:39 AM |
All electronics dead except emergency flashers
As the title says the only thing on the car that functions are the emergency flashers. Nothing else responds at all. The battery is healthy and freshly charged, I have juice (only 9.5Volts?) at the ignition switch, a new ignition switch (and the old one tested out fine as well), and I've played with all kinds of grounds. I've added grounds from the motor to battery and from battery to chassis just trying to rule things out. I can't find any visible issues or broken wires. I've had a finicky coolant temp gauge for a while and I've also noticed that the wideband doesn't always want to start giving reading when the fog lights are on. If I would cycle the fog lights the wideband and fogs would both work great. The wideband is grounded with the radio... The harness in the car has obviously been altered in the past, but I have no idea why or how. Everything is nicely soldered and all the connections were then covered with heat shrink tubing. The car has run great for months and now its completely dead. It played possum once in June for about 20 minutes. Then as summer progressed the car would struggle to crank or not crank when it was warm, and now its a constant dead system.
Where are the grounds under the dash on an early 944? Why would potentially bad dash grounds lead to a no crank scenario? I really doubt that all the stock grounds suddenly failed together and that the addition of extra 4 gauge wire grounds isn't enough to at least get a power window or radio. Ideas?
