-   -   Turn signal problem (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/772872-turn-signal-problem.html)
ted944 09-22-2013 03:46 PM
Turn signal problem
My left turn signal flashes really fast so I thought the bulbs might be bad.
When checking the lights, the front left is dark and the rear blinks fast.
I replaced both the front and rear left turn signal bulb. The problem is still there.
The front still doesn't work, the rear light blinks fast.
Any idea what I should check next?
alan6272 09-22-2013 05:42 PM
wiring issue on front first check for power if good then check the ground
