Headlights wont come up!
Hi Guys, was wondering if you could help me figure this out.
A couple of night ago,after stopping at a store on the way home the headlights would not pop up at all , they were working fine just before. I replaced the fuse but still no luck,what should I look for next? Thanks so much |
The relay on the headlight motor, perhaps. Do the lights come on but stay down?
Currently have: Guards Red 1987 924S 16v -- Light Blue Metallic 1980 928 Gone: Minerva Blue 1979 928 -- Gray 1985.5 944 -- Black 1989 944 -- Black 1984 944 -- Black 1987 944S -- Alaska Blue 1974 914 1.8 -- Guards Red 1983 944 -- Guards Red 1987 924S -- White 1988 924S -- Maraschino Red 1987 944 Turbo -- Beige 1981 924 -- Red 1984 944 |
You can raise them manually too
In case you didn't know, in a pinch you can pull the "boot" dust cover off the headlight motor (where the relay is) and there is a knob that you can turn to manually raise the headlights. As for your problem, the relays and grounds if it is not the fuse, then the motor. Be sure to clean and re-grease the linkages every few years, it makes it easier on the mechanism which would draw fewer amps through the relays than dry, rusty, high friction linkages. Good luck and have fun.
1988 Silver 924-S Original owner Porsche 924S: The 944's cheaper, faster little sister.
The headlights do turn on but they won't come up, relays?
Sounds like a motor issue. I would try the relay on the motor itself first--I've heard that it's a major cause of this problem.
AFM #725
I had this issue, was the relay. +1 On manually raising the headlights with the knob on top of the motor. Very cool
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio http://www.gawerracing.com |
Sometimes just removing and replacing the relay will make things work, Check out the link below from 944Foot2thefloor.com.
944 Foot To The Floor: How To Troubleshoot Porsche 944 Headlight Problem Cheers, Larry
Retired USAF and Civil Service, 1985.5 NA Graphite Metallic, A never ending work in progress, 1992 968 Horizon Blue Cab "New Toy"
So I haven't posted on this forum before, I'm usually on the 911 tech site, but did you check for a bad fuse? There are a total of three fuses on the later 944's. One for driving the lights up #37(7.5amp), one to drive them down #16(7.5amp) and a 25amp #2 for the motor. I just sorted mine out, the PO had pulled the relay that's located on the motor unit next to the connector and had been opening and closing them manually. I cleaned and lubed the motor drive, replaced the relay and confirmed that all three fuses were good. Warren
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
