Under the car
Heater valve on the early cars
My heater valve body split in half a while back and I need to get a new valve. How many others have had theirs split and does a new one from pelican hold up well? I'd hate to replace it just to have it split again in the near future.
Any insight?
Old 10-02-2013, 01:31 PM
Proprietoristicly Refined
John_AZ's Avatar
Interesting. The early 944 & the 924S use the same heater control valve.
I replaced mine in Jan. 2007 when I replaced the head gasket in the '87 924S. It had a trace of dried coolant but not "split."
I bought the OEM from Pelican and no problems.
Pelican Parts - Product Information: 944-572-085-02-M53
If you are worried--do not go cheap aftermarket and get the OEM.
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 10-02-2013, 04:25 PM
AFM #725
Gawernator's Avatar
My valve was still okay after 26 years and I replaced with a new OEM to be preventative and it's still good as well
Old 10-02-2013, 07:53 PM
tamathumper's Avatar
Mine was still good, but I just replaced it. They do fail a lot on the 968 because they're right above the exhaust manifold. The hall sender connector fell apart and they are right next to each other, so I figured it wouldn't be long before it failed too.
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 10-03-2013, 03:24 AM
Just thinking out loud
mattdavis11's Avatar
I've never had one fail, but it has been replaced.
91 FJ80
84 Ram Charger (now gone)
Old 10-03-2013, 04:55 AM
Back from Beyond
Mine failed on my 83 but only as a result of drastic overheating. It's the only one I've seen fail.
Old 10-03-2013, 05:38 AM
Andrew Gawers' Dad
CHICKS's Avatar
The original in my 86' was still "ok", but I did replace it with a new OEM one from Pelican when I had the motor out in August.
Old 10-03-2013, 05:40 AM
I replaced mine with the Pelican one about 3 years ago and no problem so far.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 10-04-2013, 08:40 AM
