-   -   Turn signal stalk won't go up (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/777942-turn-signal-stalk-wont-go-up.html)
Gawernator 10-23-2013 01:04 PM
Strange issue with my turn signal. When I got this 944 years ago the turn signal cancel never worked but I had much bigger issues to attend to. Now that I'm running out of things to fix (hahahaha jinx) I'm trying to tackle the turn signals. I tried the electrical tape fix Our Photo Album but that didn't change anything, didn't try to add more tape. A couple months ago I noticed the turn signal stalk will move down and turn on the left turn signal but I can't push it up far enough to turn on the right turn signal. It just hangs up... if I pushed hard it would probably snap. What could this be?
Slam 10-23-2013 02:22 PM
You're gonna have to find a route to work with only left turns...
Time for a new switch. Pull the steering wheel and see what you find. Maybe the pipper broke off the steering wheel's wiper ring.
mytrplseven 10-23-2013 02:23 PM
Replace the whole shebang and then you'll have more time for other surprises.
Gawernator 10-23-2013 02:32 PM
Yay. Well, maybe after I drop another $$$$$ on another paint job next month :) pics will be available!!!!
curtisr 10-23-2013 05:38 PM
Hmm, mix a little Cialis in with some lube???
Slam 10-23-2013 08:47 PM
Bwahahahahahaha!
Gawernator 10-23-2013 09:10 PM
The peanut galley yet lives
v2rocket_aka944 10-24-2013 06:19 AM
steering wheel might be on too tight.
had this happen before.
Gawernator 10-24-2013 11:14 AM
Thanks Spencer
