A giant power steering leak?
On a 944, at the steering rack, I pulled one of the boots and a puddle of atf poured out. Does this mean it's a bad rack?
Can someone please confirm that the boot should not carry any atf? I've always thought that boots protect from debris, but are not intended as a seal. Thanks a lot! |
You are correct, there should be no fluid present in the rack boot.
This does not mean that you have a "bad rack" - it most likely can be resealed. If you are up to the job, you can purchase a reseal kit for ~$75. If you do not want to do the job yourself, you can purchase a rebuilt unit. Many of the online forums that offer parts support also sell rebuilt racks - including Pelican.
1981 924 Turbo 1987 N/A Auto Black w/Can-Can Red Interior |
+1 - *no* fluid should be in the boot.
Same with girlfriends, if there's fluid in her boots, she might have a bad rack, and those ones can't be resealed. In that case it's best to just replace with new.
'78 924 "NA" '87 944 "S" '93 968 "SC" |
lol.
Thanks you guys. I'll get a rebuild kit. Have you guys had to have steering re-aligned after you rebuilt the rack? I read the "10 cautions" on Arnnworx and it's a little daunting. I think I can do it, though. Thanks again! And happy halloween. |
Proprietoristicly Refined
Resealing a rack may not be possible if the main shaft is bad:
Steering Rack Get a rebuilt rack with a warranty. Change the tie rod ends. Do not use a "pickle fork". Rent/deposit the tie rod end remover tool at AutoZone. Mark the steering shaft coupler before you remove it to get it back in the right place. I used a DIY alignment process before and after. Alignment record table: http://members.rennlist.com/captearlg/928recordtable.html Get new rack bellows if yours are rotted/torn. Do Not Use a Power Steering Stop Leak! Easy 4 hours or less job--maybe not. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
One more question because I am unsure. If I put in a rebuilt rack, do I need an alignment?
Thanks. |
Yes.
Almost impossible to keep exact alignment when you install the rack and screw in the tie rod ends. But, as I mentioned If you get the old numbers and record them, on current toe-in and camber, you can get close as your current setup. An easy alignment setup: Pelican Technical Article: Home Alignment J_AZ
When replacing tie rod ends count the number of turns/twists to unscrew the tie rod end from the rack and re-install the new tie rod end with the same number of twists. This will restore the alignment to whatever you started with.
