-   -   Failed smog at idle... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/779602-failed-smog-idle.html)
mhariush 11-08-2013 03:11 PM
Good stuff. I'm getting ready to get my S smog cleared.
Sorting out a running hot issue, changed coolant temp sensors, fixed vacuum leaks, replaced O2 sensor. I want to keep the original cat, so I think the Alcohol is an interesting tip.
Gawernator 11-08-2013 05:30 PM
Alcohol definitely not necessary. Here are my results, when I first bought the car, before doing any of my improvements (pretty poor condition): http://forums.pelicanparts.com/uploa...1383960593.jpg
Curious to see how it does next year as a basically brand new car lol (all new vacuum lines, ignition parts, fuel system etc)
mhariush 11-08-2013 05:40 PM
Hm, Mike, you tested in California yes? Why isn't there a result for NO (PPM) as Gaw's and mine. That's what I failed on...
Mike_944 11-08-2013 08:37 PM
Yes I tested in central Cali. It might be different by county. Just get it smogged in my town. lol
Gawernator 11-08-2013 10:01 PM
Contra Costa county tests for that.. and NOx is pretty much related to your cat. We'll see how mine does after I put my converter pipe back on lol...
Also I drove like 5 minutes to the smog station, and then waited for like 30 minutes to get the test done. With the cat nice and hot after some good driving I'm sure the NOx will go down a lot
