'87 turbo central warning light on with seatbelt and airbag light
Just acquired an 87 Turbo /W central wrning light on, PO said it was the emer. brake button, which i fixed but the light is still on, now along w the seatbelt and airbag lights. Any direction for troubleshooting?
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
any ideas?
In the Fires of Hell.....
Just do the airbag reset trick detailed out in Clark's Garage. There may be nothing at all wrong.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost |
Maybe related to the plugs behind the cluster?
I recently pulled my cluster to clean the grounds (speedo wouldn't pick up until 20mph....). Put it back in....and I have the same lights on. Frustrating.....
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
Guys, if you pull the cluster with the battery connected and turn the key on while everything is not hooked up properly, you will trip the air bag computer and get those 3 lights.
Do the reset procedure in Clark's Garage, and you should be fine. Next time you play with the cluster make sure not to touch the key until everything is back together. Air Bag Warning Light Reset
Thanks!!
thank you KD I'll let you know if that works, might not get to it til Sun.
