[924] don't start anymore. Need help.
Hello,
i have a problem with my 924 (year 81, transistorized ignition). It doesn't start anymore since last week. last friday, i cranked 2 times, starter ok but the car didn't start. The third time, it starts nicely and i drive home (4km) saturday, i cranked and the car started nicely then i stopped. monday, i cranked, starter ok but the car don't start anymore. Test 1 : I shunt 30-87 of fuel pump relay => fuel pump ok. Test 2 : fuel pump relay out to not flood the engine. I take off one spark plug. I crank => no spark. http://forums.pelicanparts.com/uploa...1383489378.jpg Test 3 : fuel pump relay out to not flood the engine. I take off one spark plug but plug it directly on the coil (terminal 4). I crank => no spark. http://forums.pelicanparts.com/uploa...1383489492.jpg Measures : resistance between ignition coil terminals 1 and 15 : 2,5 ohms resistance between ignition coil terminals 4 and 15 : 7 KOhms tested spark plug cable resistance : 2KOhms distributor/coil cable resistance : 2KOhms With ignition on. voltage between ignition coil terminals 15 and ground => 6,45 V voltage between ignition coil terminals 15 and 1 => 5,02 V voltage between ignition coil terminals 1 and ground => 1,43 V Can you help me ? |
| All times are GMT -8. The time now is 04:59 AM. |
