Endat's Avatar
My 16v Engine Build
Finally doing my build.. 1987 Porsche 944S that had a timing chain failure.
The block and all internals have been to the machine shop.. dont remember the cost, a few hundred maybe.
The crankshaft is in place...
Old 11-17-2013, 06:33 PM
Custom User Title
mikepellegrini's Avatar
Very, very pretty!
83 944 NA - Black on black
86 951 - Red
97 Ford Expedition
He who hesitates is lost.
Old 11-17-2013, 06:56 PM
Endat's Avatar
Wrapped my pistons and rods and connecting pins in oil after the machine shop.. had the pin bushings replaced and got some new nuts as well.
Old 11-17-2013, 07:00 PM
Endat's Avatar
Rings
Repeat 3x
To be continued...
Old 11-17-2013, 07:17 PM
I've all ways wanted to get in to the bottom end of mine, cool to see it all. best of wishes on the rest of the build.
Old 11-17-2013, 07:36 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Endat:
Nice Pictures. Looking forward to it being finished. Any upgrades?
Keep us updated, Thank you in advance.
Later...
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968 & 911 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 11-17-2013, 10:25 PM
That Guy
Techno Duck's Avatar
Were those cylinders honed for Alusil? Maybe its just the pictures, but the crosshatch on the bores worries me. They should look almost smooth.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 11-17-2013, 10:28 PM
That's what I was thinking
Old 11-17-2013, 10:44 PM
Eric
It does look rougher than normal. Bores normally look a little grey not silver.
Eric
Old 11-18-2013, 12:31 AM
Just had my 3.0L 968 block honed (polished) and it has no cross hatching either...
Old 11-18-2013, 02:55 AM
9FF 9FF is offline
9FF's Avatar
Looks like it hasn't had the AN-30 finishing after it was honed.
Old 11-18-2013, 03:09 AM
Endat's Avatar
So is it going to explode?
Guru944: No upgrades except a little head work.. and wrinkle red powder coat for the intake and valve cover.
2001 Porsche Boxster
1987 944S
Old 11-18-2013, 06:38 AM
9FF 9FF is offline
9FF's Avatar
It will wear out very quickly if the silicone hasn't been exposed (AN-30 lapped & finished). If you need the KS engine repair manual for your builder pm me.
Old 11-18-2013, 07:03 AM
That Guy
Worse case scenario is a ring will break or a piston will seize. Best case scenario is the rings probably wont ever seat correctly and it will have low compression. This is important!
Jon
Old 11-18-2013, 07:09 AM
wilkrod's Avatar
Something ain't right!
Jeff
Old 11-18-2013, 07:56 AM
Endat's Avatar
Seems like it's too late for that now...
Old 11-18-2013, 09:48 AM
It might gall and gouge a cylinder wall just turning it over on an engine stand. It could wreck the block to not address this, although I do not know what your clearances will be like if it's taken apart and lapped properly now.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 11-18-2013, 10:11 AM
Endat's Avatar
So it'll destroy the engine.. solutions anyone?
Old 11-18-2013, 10:15 AM
tamathumper's Avatar
Sorry, man. The only solution is that it needs to be disassembled and done right. These cylinders can't be honed the conventional way. The silicon needs to be "standing proud" of the aluminum surface.
Honing Options for Hypereutectic Aluminum Cylinder Bores - Sunnen
'78 924 "NA"
'87 944 "S"
'93 968 "SC"
Old 11-18-2013, 10:42 AM
9FF 9FF is offline
9FF's Avatar
I'm feeling the suckiness of this dilemma. The machine shop should have known if they had any engineering knowledge, but that doesn't help you I suppose.
First, you need a shop that either knows these engines or is willing to read-up and learn. Any shop with Mercedes, BMW, Porsche engine experience should know.
They need to have a diamond hone for a quick pass through to make sure everything is right.
After honing they need to lap AN-30 paste using felt pads to expose the silicone particles. Basically the AN-30 removes aluminum from the bore but leaves the silicone on the surface.
Get your piston skirts coated at Swaintech. It's relatively cheap and the coating is Alusil compatible. They can also apply a few coats to match the clearance you are left with in the bores.
Get some new rings and gap them accordingly, iaw the FWSM.
Old 11-18-2013, 11:28 AM
