rear wheel bearing grease leakage?
I have some greasy buildup inboard of my wheels (I will try to get the pic over here soon). I figure this is either from the CV boot or the rear wheel bearing area.
is this typical leakage from either area? one of my bearings is rather new - so it might be buildup from the previous one that was not cleaned off. my cv boot is not new, but OK. I could give it another good squeezing to check for problems later.
87 944 NA
Old 11-24-2013, 05:26 AM
here's the pic - not sure how come I can't put it in the original posting...
87 944 NA
Old 11-24-2013, 06:52 AM
944tothefloor's Avatar
Looks normal. Some leakage. A lot of it is road debris. Those bolts often get covered in gunk like that -- make sure to clean them before removing them.
Old 11-24-2013, 06:03 PM
AFM #725
Gawernator's Avatar
Man, your boots and parts make my 944 looks clean and newish
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 11-24-2013, 09:52 PM
so this is a sign the bearing is losing grease - is there a way to pack some more grease in there without breaking the 350-foot-pound nut off?
87 944 NA
Old 11-25-2013, 02:16 PM
Toofah King Bad
Rasta Monsta's Avatar
The bearings are sealed. . .no reliable way to add grease and replace seals.
Don't let that nut slow you down. . .take it apart and replace the bearings if you are committed to keeping the car. Arn has a good tool for the project.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-25-2013, 02:50 PM
9FF 9FF is offline
9FF's Avatar
I'm guessing that is from your CV joints and not your bearings. CV's have a ton more grease to leak out than bearings and as Rasta said, they are sealed bearings.
If your bearings are not making noises or your CV's aren't clicking, I would plan to repack your CV joints in the near future.
Old 11-25-2013, 05:14 PM
I haven't done it yet but multiple owners have actually injected cv grease through the boot to the joint, with something like a marinade injector. They have had surprising success. Of course if you decide to puncture the boot, keep the hole as small as possible. Good luck in any case!
Old 11-25-2013, 05:27 PM
I wouldn't dare poke a hole in those boots. They're known to rip and sling grease as it is, which may be your problem. Carefully inspect your CV boots for any tears. If you've never rebuilt the CVs and replace the boots, I'd suggest getting the kits. And do some reading before you take the actual joints apart...!
Old 11-26-2013, 06:03 AM
AFM #725
Gawernator's Avatar
Talk about the lazy and incorrect way to re grease...
Old 11-26-2013, 07:07 AM
