I've got a 1986 944 and I'm having problems with my battery holding a charge. Battery is brand new and the alternator was rebuilt last week. When jumped, the car drives just fine and has a strong charge. When I let it sit for a couple hours and then try to start I get nothing. Something seems like its drawing power while the car is off, and enough power to cause the battery to go dead within a couple hours. Its not my headlamps (made sure they're off), interior lights (never on) or my headlamp motor (needs replacing and is unplugged). Anybody have any helpful advice or had this problem before.....?
- Phil Long 1986 944 Base - Daily Driver |
Porsche 944S Club Sport
phillyphils944:
Bad Ground loop. Current is being drawn even when engine & key is off. Suggest det a digital DMM Volt meter and measure your engine and every Ground point to (-) battery resistance and even your exhaust system (the most common oversight). Next step is to start pulling fuses starting with your radio & accessories circuit. Alarm system & then your Fan Circuit (common power drain when vehicle is hot, Fan stays on and kills battery). Keep us updated. Later...
Guru944 ![]() 2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport. 1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo. http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions. Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful. |
Proprietoristicly Refined
![]() Clarks has an electrical discharge page you should read: Excessive Battery Discharge Rate And a recent post on common battery drains... common battery drains, let's have 'em... J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
Thanks for the heads up John_AZ. I'll get my hands on a volt meterand get right on it guru944... I'll keep you updated. Thanks again.
944 addict
Listen for the fans after engine shut-down. If they're one, see if they're still on 10 minutes later. That's a quick clue to a bad radiator fan switch. Make sure the engine's warm enough for the fans to come on (leave the A/C off).
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman. Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved. |
just a note: had the same thing, but took longer to kill it. turned out being a bad door jam switch for the dome light was grounding out. just a thought.
The door jamb switch also controls turning off the DME after shutting the engine off. Once you exit the car and close the door, the dme shuts off. (at least in a late car, not sure abut an early car) If there is a bad door switch the dme will stay energized. easy to test, does the dome light go on and off when you open and close the door?
However dme is not enough to kill a battery in a few hours. I once thought I had a bad alternator draining my battery and had it rebuilt, but I can't be sure if it helped or not. Has anyone else seen a bad alternator drain a battery? If it is not obvious, the first thing I would do is disconnect the neg battery cable and put a amp meter between the battery and the terminal and measure the drain. Consult Clarkes for more details. |
