1987 924s timing belt to spray or not to spray?
i have removed the timing belt cover doing troubleshooting.i am cleaning everything i can in the process.should i spray anything on the timing belt to extend life?
Old 12-07-2013, 05:20 PM
944tothefloor's Avatar
What spray? Why not just change it wyit (while your in there). Is it new at all?
Old 12-07-2013, 05:36 PM
alan6272's Avatar
no spray of any kind on the TB in fact if they get oil or anti freeze or any kind of contamination it is recommended to change the TB. I have never ever heard of a spray for the TB. I know they make a spray to quiet drive belts but that stuff does not work and in fact ruins the belts.
1983 944 ,1983 V-65 magna
catalina22 sold
baja ski boat sold
my toys
Old 12-07-2013, 05:56 PM
agreed - no fluids on a timing belt.
belt juice won't extend anything but a mechanics wallet.
Old 12-09-2013, 06:57 PM
Converted 944 Guy
What issues are you troubleshooting? If you have a balance shaft, crank, or water pump leak you might consider replacing the belts since you'll likely remove them to fix the leak.
Old 12-09-2013, 09:17 PM
