Send a message via AIM to jeh1995
Question 86NA Upshift/Fuel Economy
My upshift indicator and fuel economy guage are acting wierd. The guage doesn't move smoothly and seems to like both extremes except when I am cruising. Once at a steady speed it moves to a reasonable measurement. The upshift indicator isn't working right (ie like it used to). The tach is fine, speedo/odo are fine too. I know that the upshift/guage use tack signal, speedo signal, injector signal... it is the erratic movement of the guage that is unusual. Could this be a symptom of a vacuum leak for the fuel injection...??? Any thoughts? Car runs fine...
John
-1986 NA 944
-77k Miles
Old 08-27-2002, 07:30 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
My miles per gallon gauge is usually around 00000 and then I reach 90 and it kicks it around 25 or so. at Idle, it is supposed to read hours or min. per gallon, I forget which. once you get above 5mph or sumpin it goes to mpg. The manual suggests taking off from a stop with "light and steady" pressure on the throttle. Pretend yer racing a Hyundai Excel with a burned piston, and yer gauge should straighten out for ya.
I can't help ya with the upshift, I have a automaterical
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 08-27-2002, 07:35 PM
