Cam Housing Gasket
Yesterday I was attempted to pull off the cam housing to paint only to find it is a royal pain in the butt to get it off. Doing more research shows these can be difficult to remove and better left along if there aren't any leaks. Well now that I've pushed and pried on it, even though it hasn't come off, oil is leaking out the bottom. Should I finish what I started and just keep banging on the thing until it comes off or just bolt it back up? Guess I'm asking if the damage has already been done to the gasket or not.
Thanks,
Dustin
Current Porsches
'10 Panamera 4S, '66 912, '90 928 GT, '83 944 Track Car
Past Porsches
'06 997 C4S, '68 912, '99 996 C4, '97 Boxster
Old 12-02-2013, 06:20 AM
Just thinking out loud
mattdavis11's Avatar
Unless you like fires, I'd replace the gasket. Is there any chance you haven't removed the inner bolts?
91 FJ80
84 Ram Charger (now gone)
Old 12-02-2013, 06:26 AM
That's exactly what happened. I didn't realize there were inner bolts! doh
Thank you!
Current Porsches
Past Porsches
Old 12-02-2013, 06:28 AM
Make sure you take the timing belt off the cam too!
91 FJ80
Old 12-02-2013, 06:30 AM
A lot of work just to pretty something up!
1981 924 Turbo
1987 N/A Auto
Black w/Can-Can Red Interior
Old 12-02-2013, 03:48 PM
True but the engine is already out of the car and doing other stuff
Old 12-02-2013, 03:51 PM
Frenchy
cam gasket
I just finished rebuilding my upper motor. Two thoughts on the cam housing. When you finally get all the interior bolts out and start to remove the cam housing be sure to have a friend helping to catch the hydraulic lifters, and mark each one so you get them back in the same order. To re-torque the interior bolts use a short hex drive socket. To get the socket through the cam opening will require grinding down the outside of the socket until it fits through the hole in the cam tower.
Sounds like a great project. Also be sure to pull the cam tower all apart and replace all the seals.
Frenchy
Old 12-02-2013, 07:47 PM
Mike, can you explain what you mean by using a short hex socket? Are you saying to use a different socket solution than what I use to uninstall them?
Dustin
Old 12-02-2013, 08:20 PM
If you use a long hex bit when torquing the cam box you will typically not get it torqued to spec due to the bit twisting when under pressure. If you use a short bit you will get more of a true torque value. Unfortunately to get the short hex bit socket (socket part) to fit through the hole in the cam box you must modify either by grinding it to fit, or put it in a lathe and turn it down.
1981 924 Turbo
1987 N/A Auto
Old 12-03-2013, 02:56 AM
ok, I understand what you are saying. Thanks for the clarification.
Current Porsches
Past Porsches
Old 12-03-2013, 06:27 AM
