petrolhead611's Avatar
Send a message via AIM to petrolhead611
clutch hose
Should I dare use heat to loosen the hose nut in the clutch master cylinder? It has had plenty of penetrating oil on it without success.;in fact a quality spanner slipped on the nut somewhat rounding it.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 11-30-2013, 07:14 AM
I would definitely NOT USE OPEN FLAME.
If you are going to replace the hose, I'd use a small pipe wrench like shown. It will likely mangle the nut, but it won't slip.
If you must use heat, use a heat gun. Try not to get it hotter than you have to. If you have a pyrometer try to not go over 250F. This is the approximate continuous temp allowed for nitrile or Buna-N (the likely seal material in the clutch master cylinder). For short time periods it can be allowed to get up to 400F, but should be avoided. Also, if I were to do this, I'd take aluminum foil and blanket the area all around the nut/clutch master cylinder so everything else in the area is shielded from the heat.
Good Luck
Old 12-01-2013, 05:31 PM
That Guy
Techno Duck's Avatar
Have you tried a flare nut wrench? AKA line wrench.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-01-2013, 05:34 PM
You cannot get what I call a brake pipe spanner (a ring spanner with a perimeter slot to permit it to slide over brake pipe)on because of the large fittings and hose right near the master cylinder. I have an adjustable temperature heat gun that goes up to 400C so I will try that first if I can get it near enough.
Old 12-03-2013, 02:55 AM
