Smile 944 S2 - heater: constantly on high
I have a 1990 S2...
The heater will not shut down. It remains on high all the time. I suspect that its a control valve but I don't know where its located. Are there instructions on how to install a heater control valve, IF, that is the problem.
Just for some history: before, as I suspected something was going wrong, the heater control on the dash was very sensitive like it was either all the way on, or all the way off.
Thanks, any help will be appreciated.
Old 04-01-2014, 08:53 AM
fiat22turbo's Avatar
I had that problem on my 88 951. The control valve was buried on the firewall behind the cylinder head. It was a pain to reach, even with the intake off.
The vacuum diaphragm failed internally, but the valve itself looked fine from the outside.
I suspect you can find a diagram that shows its location if you look at PET and of course the FSM's and/or Hayne's manual will help you with whatever work you need to do on the car.
Hope this helps....
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 04-01-2014, 08:59 AM
mhariush's Avatar
did you check the heater clip?
944 Heater Fix
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 04-01-2014, 12:11 PM
I have been reading about the clip... I understand its in line about where the gas pedal is. thx
Old 04-02-2014, 06:47 PM
mhariush's Avatar
No, the clip is in the passenger side foot well.
Old 04-02-2014, 08:55 PM
marko's Avatar
On late cars, it is in the driver footwell. Clark's Garage Home Page, Heater malfunctions
'90 944S2 cab - sold after 20 years, will not be forgotten.
'04 Mercedes SL500 - Nice but my S2 was more fun to drive.
Old 04-03-2014, 12:49 AM
Shifter's Avatar
On the S2 the heater valve is on the passenger side, right next to the oil filter. Zip tie it closed to see if the heat turns off. That being said, when I had this issue with my S2, it was the clip.
Old 04-03-2014, 09:19 AM
darnellsgarage
Consistent heat. Clip nearly every time.
don
Old 04-05-2014, 08:59 AM
