Replacing/testing microswitches (powerlocks)?
Has anyone tested the microswitches in the doors? if so? how? Where is it located? I pulled the door panels off and the powerlock actuators, but I still can't see it. Is it in the tumbler?
All I get from the central unit is one click (pressed once), press again...two clicks.....the switch is working with the central unit as far as I can tell.... but doors don't open or close anymore. I have another central locking unit....and swapped them, and still the same. |
I don't know where they are but I have the problem that I can't close both doors from the driver's door but can do so from the other door. Would the driver's side microswitch be the problem?
Mine was opening the drivers only for a long time then it failed.
There are microswitches on both doors.... Not sure.... any guesses...?? |
| All times are GMT -8. The time now is 08:44 PM. |
