In the Fires of Hell.....
kdjones2000's Avatar
Oil Pickup Tube Porn :)
Setting up an engine for our new 944 Spec / Chumpcar. Obviously the objective here is to make it as reliable as possible, especially the oiling department.
1) Cross-drilled the crankshaft, adding an additional exit hole for oil to keep the connecting rod bearings lubricated. I realized later that the better way to do this was to ONLY drill #2 and #3 journals, so that they are the ones that get more oil. Maybe on the next one, I guess.
2) Lindsey Racing oil pickup tube ring and Ishihara-Johnson reinforcement. Both items were MIG'ed to the pickup tube per vendor recommendations.
Final installation on the block:
3) Lindsey Racing oil pan baffle. Welded into the Aluminum 8R pan per instructions:
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 12-27-2013, 12:51 PM
9FF 9FF is offline
9FF's Avatar
Originally Posted by kdjones2000 View Post
... realized later that the better way to do this was to ONLY drill #2 and #3 journals, so that they are the ones that get more oil. Maybe on the next one, I guess....
Very nice, thanks for sharing.
Yes Porsche realized after the 83's that a cross-drilled crank added nothing, instead just make 2&3 bigger than the rest or as you said just cross-drill 2&3 in future.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 12-27-2013, 02:44 PM
Just thinking out loud
mattdavis11's Avatar
Very nice indeed!
Not sure I can agree with that. I can't ever remember hearing of an 83 that spun a rod bearing. I know mine were in unbelievable shape when they were changed. They looked brand new at nearly 150K miles.
91 FJ80
84 Ram Charger (now gone)
Old 12-28-2013, 05:14 AM
AFM #725
Gawernator's Avatar
sexy
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 12-28-2013, 06:15 PM
