924T High Idle
I recently purchased a 1982 924 Turbo. It recently received new timing belt and radiator upgrade to 944 style. Car starts fine, but it idles high, 1500 rpm. I tried adjusting the idle screw but it didn't do much. Any suggestions?
Old 01-05-2014, 06:46 PM
AFM #725
Gawernator's Avatar
vacuum leak?
Watchdog Armory Racing AFM #725 Thanks to my 2017 Sponsors: JPH Suspension | AXO | Armour Bodies | BELL Helmets | Braven | EVLUTION Nutrition | Forcefield Armor | FunTrackDayz | Galfer | Motion Pro | MOTUL | Matrix Racing Concepts | ODI Grips | OGIO | Shorai Inc. | SPEEDMOB | Vortex | Woodcraft | Wicked Audio
http://www.gawerracing.com
Old 01-05-2014, 09:44 PM
924RACR's Avatar
The idle adjustment screw won't actually change the idle speed - that's managed by timing. So if it's that far off, yes, vacuum leak.
Have all the vacuum hoses and elbows already been replaced? There's a lot of 'em, including some rather-well-hidden ones...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 01-06-2014, 05:24 AM
fiat22turbo's Avatar
Not too mention the throttle body itself, which can have shaft leaks and cause idle issues. Time to spray some water with a spray bottle on an idling engine to see if the throttle body, injector holes, vacuum lines/fitting or intake tubing is leaking.
Good luck!
Stefan
Portland, OR
1979 Porsche 924 Carrera GTS (clone-ish)
1988 Porsche 944 Turbo S (Silver Rose)
Old 01-06-2014, 10:21 AM
have you tried cleaning out the TB with some carb cleaner? my old 944 had a gunky TB flange that contributed to crappy idle.
Old 01-06-2014, 06:11 PM
Thanks guys. Great suggestions. I was thinking along these lines, but it is great to get some support.
Josh
Old 01-06-2014, 06:25 PM
Adjustment procedure below.
924Board.org :: View topic - Idle speed adj for '81-up 931 (+throttle stop set procedure)
Credit to 'Smoothie' and his great posts.
Old 01-07-2014, 04:55 AM
ideola's Avatar
Throttle body reseal kit.
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini
Old 01-07-2014, 08:12 AM
924RACR's Avatar
I did just use the above TB reseal kit on my car (an 82), pretty straightforward... I know I did have leaks before, though I can't comment yet on performance after as I haven't driven the car since the rebuild...
The symptoms were very amusing, as the idle would be high sometimes but not others - mainly based on engine warm-up... don't remember if it was high when warm or when cold...
Vaughan Scott
http://www.924.org
Old 01-08-2014, 05:57 AM
