hub details
the hub (well, mine anyways - and the brake rotor surface that it mates to) have a concentric circular groove pattern, on the mating faces. so if you scrape your fingernail towards the edge, it will grab the ridges. the ridges are slight.
is there a functional significance to this pattern? I imagine it could be important to avoid flat pieces of aluminum hub and steel rotor welding together under heat. then there's the brake grease which should keep them healthy.
reason I ask - taking the corrosion off is requiring some more detailed brass-brushing/sanding. hope to post pics soon.
related to another thread of mine: basics : removing brake rotors
87 944 NA
Old 01-04-2014, 08:03 AM
That Guy
Techno Duck's Avatar
Those are just machining marks.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-04-2014, 08:05 AM
