-   -   Ate caliper rebuild : rear spring clips (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/791660-ate-caliper-rebuild-rear-spring-clips.html)
Bukowski 01-13-2014 05:43 PM
The shop manual says to not mix up the spring clips from the rear calipers. I seem to have done so. They have a subtle shape difference - one arm is straighter than the other.
Which arm goes on which side of the cylinder - or any other clues?
Gawernator 01-13-2014 11:26 PM
Um..... I remember them being basically the same
kdjones2000 01-15-2014 09:19 PM
I just did my rears tonight, and yes the two arms of the springs are indeed different.
Did you mix up your L/R caliper parts, so you don't know which one goes with which cylinder?
From what I can tell, the more bent arm goes on the same side as the bleeder.
Don't forget the 20 degree rotation for the piston as well.
Bukowski 01-16-2014 05:42 AM
I mixed up the clips. The bleeders go up. The other pieces are evidently exchangeable.
Do you have an explanation?
kdjones2000 01-16-2014 08:12 AM
Ummm, I looked at my calipers?
