-   -   shift knob boot (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/794068-shift-knob-boot.html)
raykutner 01-29-2014 08:04 AM
shift knob boot
any shortcut tricks on putting on a new leather shift knob boot and insert for 1983 944?
Ky914Newbie 01-29-2014 08:17 AM
I don't remember the size, but I was able to use a hole saw like you use on a drill. It was slightly smaller than the hole for the insert and I was able to use the teeth on the saw to grab the leather and push it in further by using the BFH (big effen hammer) to push the hole saw further into the recessed area for the insert.
The insert is easy to break removing. Be careful and you may get lucky like I did.
I was doing this on a late series, but I imagine the issues are similar.
Good luck.
PorscheChef 01-29-2014 08:19 AM
I've warmed up the leather with a hair dryer first. It lets it stretch a little more.
BReif61 01-29-2014 09:06 AM
I suggest sitting down in front of a good movie or sporting event and just start pulling and stretching.
9FF 01-29-2014 10:25 AM
Curious, if you can recommend a movie that is best suited for pulling and stretching ;)
J1NX3D 01-29-2014 10:31 AM
Shifter Cover Instructions - Only944.com Awesome new Porsche 944 parts
BReif61 01-29-2014 03:07 PM
Nothing that will make it past the text censors :D
