Feul Line Leak
I am in the process of purchasing an 89 944 base model. There are several minor items it needs, but a major one if a fuel line leak at the fuel rail. I tried to find a replacement part but so far I have had no luck. Also I am not sure it needs to the the entire hard line and flexible portion (ouch). Can the flexible portion be replaced with regular high pressure fuel line? Anyone had this issue before? I pick up the car later today so I will be able to take a better look at the situation.
Thanks in advanced for your help, Rick.
-Rick Central PA
1989 Linen Grey Metallic 944 Automatic (Daughter's first car)
1984 Slate Blue Metallic 911 Cabriolet ROW, 220 WHP, Steve Wong Chip, Fabspeed Muffler, Cat Bypass.
1987 Black 944S - SOLD 1969 Aubergine 911T - SOLD
Old 01-31-2014, 05:18 AM
Proprietoristicly Refined
John_AZ's Avatar
Replace both fuel lines and the short jumper.
Jumper part:
http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=944-110-413-02-M100&catalog_description=&Fuel%2520Line%252C%2520Fuel%2520Rail%2520to%2520Di aphragm%2520Damper%252C%2520%2539%2532%2534S%252C% 2520%2539%2534%2534%2520%2520
Web/Pelican has late 944 DIY on the lines--easy
I did a write-up for my 924Ss and early 944s to explain:
Fuel line replacement-924S & early 944s
Search for fuel line/engine fires if not replaced.
GL
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 01-31-2014, 05:31 AM
AFM #725
Gawernator's Avatar
Replace it all or cry
Old 01-31-2014, 06:30 AM
That Guy
Techno Duck's Avatar
944 Fuel Line Kit 1985.5 - 1989
or
FUEL LINES 944T / 944 at LINDSEY RACING - Your Porsche Performance Parts Center
Replace the jumper line also.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-31-2014, 06:45 AM
Fuel Lines
Thanks guys. I agree it is best to all of them. "Engine Fire" is not a story I want to tell. -Rick
-Rick Central PA
Old 01-31-2014, 08:36 AM
Andrew Gawers' Dad
CHICKS's Avatar
I think you can get the Rennbay lines on amazon and get free two day with prime iirc. But + 1 to Products
Old 01-31-2014, 02:47 PM
BoxsterGT's Avatar
Porsche Crest
This is what my replacement looks like............
You cut the hardline mid-way up the right fenderwell and connect the replacement part........
Please email me for details. No PMs, no PMs, no PMs.
Len at Autosportengineering dot com
Old 02-01-2014, 02:13 PM
Replacement Fuel Line
NOW I understand. I was still unclear about how I was replacing the end that was crimped to the hard line at the factory. Thank you. I'll be ordering it tomorrow. - Rick
-Rick Central PA
Old 02-01-2014, 04:43 PM
