-   -   A/C Help (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/79463-c-help.html)
Carroll Laird 09-03-2002 07:03 AM
A/C Help
My son has just moved to the Pensacola, FL area and has discovered his A/C system is low on freon http://www.pelicanparts.com/support/smileys/burn.gif. Good ole Florida sun and humidity has a way of showing up those weak spots. It has a slow leak that requires refilling about every 3 years (probably the compressor shaft seal but the leak is too slow to find). Can anyone recommend a good shop for A/C work in that area? He also needs a shop for normal maintenance items (belts, brakes, etc.) . He has an 85/1 NA. Thanks in advance for the help!
Cebu 09-04-2002 03:07 PM
If the system has been converted to R-134a, ther is stop leak available.
