ASE Master
alfadoc's Avatar
ABS light
Just completed engine and subframe swap on my S2, and the ABS light is on at startup and will not turn off. Any suggestions where to begin diagnosis?
Old 03-09-2014, 04:04 PM
Swap? From what to what?
If it comes on right away that's usually a disconnected wheel sensor (or broken wire) I'd ohm all the wheel sensors at the ABS brain. It could also be the ABS relay.
1987 928S4
1992 968 cabrio
2009 957 Cayenne GTS
Old 03-09-2014, 05:07 PM
ASE Master
alfadoc's Avatar
From a grenaded S2 engine to one that works correctly. Maybe I missed hooking up one of the wheel sensors. Thanks.
1989 944S2 (sold after 11 great years)
1980 911SC Weissach (bucket list car)
1975 914 1.8 (future restoration)
1993 968 Coupe 6 speed (new acquisition)
Old 03-09-2014, 05:13 PM
Shifter's Avatar
Did you check the fuses? There are two of them, and either one will trigger the light.
Old 03-10-2014, 08:24 AM
924RACR's Avatar
The big clue here is that the light will typically come on, go out, then come back on if there's fault.
Since it's not going out (which is the bulb check function), most likely you have a power or ground problem...
Vaughan Scott
http://www.vaughanscott.com
http://www.924.org
Old 03-15-2014, 06:34 AM
ASE Master
alfadoc's Avatar
It actually did go out once this week. I'll get under it and figure it out tomorrow. Thanks!
Old 03-15-2014, 09:29 AM
