85 944 engine easy to work on?
I had my 85.5 944 parked for over 3 years..... It was because i damaged a fuel line while chaning the clutch.... Now I just got the fuel line and thinking of putting it together...... I am thinking of getting the engine a kinda tune up....
I am wondering if it is easy and neccessary to take the head off and do vavle jobs? and is it easy to do? Is it easy to do timing belt? Not looking into adding power just want a reliable car.... I had done similar things to honda and mitsubishi 4 cylinders, wondering if 944 would be that much different... and what are the watch-outs? Thanks in advance. |
Toofah King Bad
lol
Go to Clark's Garage and read everything there under Shop Manual, then you will be in a better position to ask specific questions.
» 1987 924S Turbo - Got Boost? « "DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc |
Why do you think it needs a valve job? Low compression? Burning oil? Oily plugs and/or valves? How many miles are on it?
Get ready to spend big bucks on the "while you're in there" stuff. I spent over 2k when I took the head off my 88 NA. I did a ton of things your car may or may not need (front seals, oil cooler gaskets, all new coolant hoses, etc) and that stuff adds up quick. |
Sounds like you need to drain the fuel (if you haven't already), get the fuel lines done, replace the timing and balance belts, change the oil and filter, and take her out for a good spin to get things warmed up - and hopefully then she will start speaking to you.
These cars are pretty easy to work on. Knew nothing about cars untill, and really started working on my current car (7 years), and with the help on here and the write ups on Clarks-garage really helped me out. All work was done by me, clutch, timing, head job, etc... never dove into car jobs before, and they were all straight forward, except for rusted/ stuck bolts. All you need is time, patience, and metric tool sets, and a few select Porche only tools (timing belts tools, clutch alignment, etcs.....)
Patrick
Between this (and other forums), factory service manuals, Haynes manual (for 8v motors only), and Clarks Garage, I can perform most any job, large or small.
Oh yeah, lots of time and a fairly heavy wallet are needed too...
1984 944 NA, constant tinkering 1983 "Beastie" - Safari Build |
aluminum head, block,so then are the head bolts aluminum ?no books as of yet.I would think you would wan to check compression, ajust valves.blockage in fuel.intake start at the head work your way back out to tank,air filter I could tell you about 64 to 85 ford 232 to429s
