Primer for fiberglass?
My front air dam needs some touch up. Previous owner liked to get too close to curbs. Anyway since I can't afford to have it done professionally right now, I'm going to get a spray can as closely matched as I can to my white paint. Question is what kind of primer do I use to make sure it sticks to fiberglass? Thanks.
1988 N/A 944
Old 08-30-2002, 05:55 AM
Scott R's Avatar
There is more to this than just primer. The problem is that regular rattle can primer can not flex with the fiberglass. You will only get a very short amount of time before it will all flake off. You need primer and paint that contains "flex additive."
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-30-2002, 06:52 AM
Actually, the factory front air dam is urethane, not fiberglass, although what Scott said about needing paint with a flex agent still applies.
Old 08-31-2002, 08:37 PM
Thanks to both of you.
1988 N/A 944
Old 09-05-2002, 10:48 AM
