Bringing a seriously disrespected 924 back to life.
I recently bought a 79 924. I'm sure I will be on here often to gain some knowledge and advice from those of you who have it to spare. My first and most head scratching issue is oil in my throttle body. It doesn't smoke out of the tail so I don't think it is reaching the combustion chambers but I cant figure out where it is coming from. Any ideas?
Old 02-21-2014, 07:21 PM
fiat22turbo's Avatar
Try cleaning the PCV port under the intake manifold, in the block.
Also the turbo cars added a breather to the mechanical fuel pump block off plate, might be worth a shot in addition to fixing up the breather system.
Old 02-21-2014, 09:31 PM
Proprietoristicly Refined
John_AZ's Avatar
The absolute, dedicated site for 924/931...
Porsche 924 Garage & Register home
Contents
J_AZ
ex '77.5 & 79 924
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 02-22-2014, 03:31 AM
I need a line on a good parts distributor. Where do you fellas get your parts? My local parts stores can't get anything more than plugs and filters.
Old 02-22-2014, 10:42 AM
Thanks for the reply. I checked and cleaned the PCV port but there is no PCV. Just hoses. Looking for a place to order parts.
Old 02-22-2014, 10:44 AM
Here, ********, EBS Racing, Ideola's Garage and a few other sites. Helps to look up the part numbers on ******** and take them into the parts store to cross check it.
Old 02-22-2014, 11:55 AM
Non Compos Mentis
I purchase any parts unavailable at the local auto parts store right here at Pelican.
Old 02-22-2014, 12:28 PM
My next issue is the engine is sluggish when I get on the accelerator to hard. As long as I accelerate slowly it is nice and smooth. But if I get more than half way down on the pedal it starts to sputter and not want to go. I am also hearing a gurgling sound from the air intake/fuel distributor area. Is there an available rebuild kit for the fuel distributor?
Old 02-23-2014, 03:25 PM
