CV joint : no gasket - why?
I recently learned that 914's have a gasket for the CV joint. maybe 911's have one too, I don't know.
sooooo - why isn't there an official gasket for 944 CV joints?
87 944 NA
Old 01-05-2016, 09:53 AM
first immediate thought is that the gasket might serve as a sort of heat isolator on those cars.
a big air-cooled lump bolted directly to the transaxle conducts a lot of heat which would find its way to the axles...maybe the paper is enough to minimize heat transfer from the transaxle to the CV joint/grease.
whereas the 944 has 7 feet of separation from the heat-pump.
Old 01-05-2016, 10:18 AM
kwikt 911's Avatar
Wondered the same..... my 911 has them hmmmm
Old 01-05-2016, 03:07 PM
Audi uses them on their cars. My Audi 5000 has them and it's certainly not air-cooled. Plus any heat is going to be transferred through the bolts anyway. The gaskets are more for keeping the grease from finding its way out under centrifugal force. Why they didn't use them on the 944, I'm not sure but I'm thinking about using them on mine the next time I have to tear down those axles.
Old 01-06-2016, 04:55 AM
The Audi still has the big hot engine bolted to the transaxle, and the bolts only allow limited heat transfer versus the whole face of the stub axle.
You could compare it to the phenolic intake spacers made for some cars - questionable power benefits, but the manifold is much cooler to the touch after a hard run, if that is worth anything.
Not saying my idea is THE answer...just speculation.
Old 01-06-2016, 04:57 AM
They use them on the rear differential also... My 5000 Quattro uses them on the front and back. The manual transmission in the 5000's are the same as the 944 transmission. Not to mention grease is pretty decent heat transfer substance in itself, no?
Old 01-06-2016, 05:05 AM
According to Clark's: "Over time, the grease in the CV Joint tends to disappear, even on CV Joints with boots that are in perfect condition. Don't ask me where it goes, I don't know."
Has the cause been found?
Old 01-06-2016, 03:04 PM
Some engineer in Stuttgart was drawing the rear axle assembly, sneezed before he drew a gasket, and then forgot what he was doing and sent it off to production...lol
Old 01-06-2016, 03:35 PM
plays with toy cars
sausagehacker's Avatar
I've had minor evidence of CV grease being flung up onto the underbody, I torque them to spec in a pattern (similar idea as lug nuts) to where the pressure is evenly distributed. I just repack every year, it's cheap and takes 15 minutes for everything. But gaskets would probably help.
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 01-06-2016, 05:16 PM
I've never seen one that did not eventually sling a little grease out. Gasket or not. But the gasket would definitely be a little bit of help, I would think. I think what causes some of it is that there is usually some grease that gets on the mating surfaces of the bearing and the flange during assembly. It's pretty hard not to if you ask me. Some grease gets in there and even if you torque things down, it still creates a pathway for any additional grease to get out especially under the centrifugal forces of the normal rotation of the bearings.
Old 01-07-2016, 04:46 AM
clamping force to transfer torque decreases when the mating surfaces are not clean.
search and read some grady clay threads on cv joints.
Old 01-07-2016, 06:38 AM
Not to mention the fact that grease and oil are designed to prevent surfaces from making contact with each other to start with. :-)
Old 01-07-2016, 06:54 AM
interesting, thanks everyone...
87 944 NA
Old 01-07-2016, 07:50 AM
curtisr
curtisr's Avatar
Hmm, Gesundheit sounds like gasket to me. In English anyways.
Watched Van's CV repack video. He is using one from a 914 and I don't recall any caveat about a washer.
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car -- sold)
1987 924s Garnet Red (currently becoming Lowencash II)
1982 928 Silver (sold)
Old 01-09-2016, 05:34 AM
curtisr
curtisr's Avatar
Back in the day when only Campagnolo grease would do for one's bicycle wheels it would drive me crazy how quickly the stuff would dry out. It seemed that the oil release ingredients would evaporate or something. This was true of all of the lithium based greases I tried and then along came Phil Woods and SuperLube. Troubles were over.
Old 01-09-2016, 05:57 AM
Just thinking out loud
mattdavis11's Avatar
I might be dead wrong, but moisture absorption by the gasket could lead to premature failure of the joint. We do have lower heat points on the motor where anaerobic sealant is utilized in lieu of a gasket.
91 FJ80
84 Ram Charger (now gone)
Old 01-09-2016, 01:44 PM
If a gasket absorbs moisture and allows it to enter the place it's supposed to be sealing, it's not really a gasket. LOL However, you could probably get away with smearing a very very thin layer of RTV on the outer 1/4" of the face of the flange and achieve some good sealing results. I might go this route on the old Quattro I'm rebuilding and the 944 next time I have to do any drive line work.
Old 01-09-2016, 01:53 PM
But a gasket can dry out when it is near a heat source. Not much heat near the CV on our cars. See v2rockets' post above.
91 FJ80
Old 01-09-2016, 02:05 PM
