Electrical-rear tail lights and side markers
My 924S is almost back on the road... The car is running great and there are no leaks at this time! I noticed though that I have brake lights and license plate lights but I do not have tail lights, reverse lights and side marker lights... I did a few days ago though? I checked the bulbs and fuses and I replaced a few and the others seemed to be good. I feel that it must be a ground or in the wiring somewhere.... Does anyone have any advice? or has expericed something like this before? Thanks for any help or suggestions you might have, Mike
1992 968 1969 911E Softwindow |
Proprietoristicly Refined
There is a ground points in the rear hatch area. From WSM.
![]() Check your fuses, did you install incorrectly or break a tab?. Are you sure the bulbs were good? One bad bulb may interfere with the others. J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo) |
