-   -   What Compression Numbers for the Turbo? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/79980-what-compression-numbers-turbo.html)
seb928s 09-08-2002 10:53 AM
What are the numbers for the turbo compression when it came out of the factory? What are some good numbers to have? Thanks a head of time.
Blackfoot 09-08-2002 02:45 PM
around 150 in a healthy engine.
<img src="http://us.f1.yahoofs.com/users/e0981142/bc/turbo_120.jpg?bcW8ni9Ai0tV.8p4">
AFJuvat 09-08-2002 03:51 PM
144 - 152 PSI
AFJuvat
fletch944t 09-08-2002 03:53 PM
If you go by the shop manual it's 10 bar or greater for a fresh engine (145 psi). However, I've compression checked a lot of 944 Turbos and I've never seen anything greater than 135 psi even on a fresh engine. However, on a fresh engine compression numbers will normally improve as the rings become fully seated. From my experience anything greater than 120 psi is acceptable.
The factory wear limit for compression is 6.5 bar (94.3 psi).
Regards,
Fletch
