Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
85 944 NA Copenhagen Blue
944 NA Power Steering pump bolt
Hi - new to posting to the forum but some great info here.
Just finishing up replacing a timing and balance belt, went to replace the power steering belt and button it up when I noticed some extra "play" in between the pump and bracket. Looks like the po replaced the factory bolt with a 1/4" hardware store bolt, 3 homemade spacers and a mangled washer - and yes the bolt was too short and had no nut.
Looking at the parts diagram it appears it should have a M8 x 65 bolt, a single spacer, washer and nut. As I have never had this apart before and the homemade spacers were not all together I just wanted to confirm that it is just a single spacer on one side required?
Old 03-13-2014, 08:18 PM
Proprietoristicly Refined
John_AZ's Avatar
For your '85 944 NA Copenhagen Blue'... Not sure if early or late.
The bolt in your picture looks longer than 65mm ??
But does this picture help?
GL & welcome,
J_AZ
1988 924S 77K July 2017 ...+ 1987 924S 145K DD (+15K est. bad odometer)
Old 03-14-2014, 08:53 AM
Ya, I should have caught that, definitely need a bolt longer than 65mm, or something more complex. It is hard to tell from the parts diagram what I need as the one I see on Clarks doesn't show the bracket just the pump and hardware. Possibly part #5 in your pic.
Old 03-14-2014, 08:28 PM
944 addict
mytrplseven's Avatar
Send a message via AIM to mytrplseven
You can see a parts diagram on 944online.com or Pelican parts diagrams. They also list the part numbers. Good luck
3 944's, 2 Boxsters and one Caman S, and now one 951 turbo. Really miss the Cayman.
Some people try to turn back their "odometers." Not me. I want people to know 'why' I look this way. I've traveled a long way and some of the roads weren't paved.
Old 03-15-2014, 06:12 PM
Old thread bump question.
On Bolt number 5 it is the short end or long end that gets screwed back into the pump?
Old 12-28-2017, 08:40 PM
GL & welcome,
J_AZ
On bolt number 5 in the pic is it the short end or long end that gets screwed back into the pump?
Old 12-28-2017, 08:42 PM
